  #1
Old November 8th, 2007, 02:02 PM
DenverDan DenverDan is offline
Unhappy 60 HP Mercury (1984) Loss of RPM at WOT
Hello to all from the High Country,
I have a 17ft. Bass Boat with a 1984, 60 HP Mercury (2-stroke, 3 cylinder).
The local Mercury Dealer recommended I use a BLACK MAX 10" pitch for the best performance/rpms. I have put new spark plugs, replaced the fuel pump gaskets, overhauled the carbs & added the new plastic floats. Replaced the impeller & the rectifier. Performed idle, shift & throttle cable adjustments. Checked the timing, which was right on the nose. Performed compression checks, (top-100, mid-115, bot-113). Also, I have added a new 19gal Moeller permanent gas tank which I use stabilizer in my fuel to prevent moisture buildup & only keep about 5-6 gallons for use for each trip. In the past I had the rpms up 5500 & it would take off like a rocket!!! Now they are maxing out around 4700-4800 with a steady increase, running around 30-31 MPH without extra persons, trolling battery, tackle, etc. basically minimum weight. When in Neutral the idle is set to 1200-1300 rpms/in forward 850rpms which (750-850) is recommended.
I used Mercury's DECARB spray which didn't seem to change my symptoms.
I originally purchased the Mercury Outboard Repair Manual (SELOC) through iboats. I have fixed & learned a lot using the manual but now I am leaning toward performing a "Cylinder Block Disassembly" , which I prefer not to do, due to the low compression on the top cylinder. The manual states a variation of more than 15 psi indicates the lower compression cylinder is defective. So my question to you being the "EXPERTS" is would new "RINGS" resolve my issue? Or should I take another approach by checking the carbs again for any fuel clogs, etc? Or if I should continue to run it as is will this cause wear on the powerhead due to the lack of RPMs at WOT? I am open to any advice at this point.
Thanks for your time.
P.S. I only use it 5-6 times a year for fishing & run it about 15-30minutes max at each interval.
  #2
Old November 8th, 2007, 09:38 PM
NathanY NathanY is offline
Default Re: 60 HP Mercury (1984) Loss of RPM at WOT
How low is the compression? Exactly what are the numbers? Have you done a leakdown test? I am going throught the exact same thing on a 90hp motor. I opted to rebuild, tore it down and it goes to the machine shop Saturday. You have a good motor to learn on. Go ahead and rebuild it.
  #3
Old November 8th, 2007, 10:15 PM
jebeebe jebeebe is offline
I rebuilt that same engine and the top cyl. was ugly. It had no compression. Broken rings (most were clear gone. Out the exaust I presume) and what was left was welded in the groves. I took the block to the machine shop and the guy honed it and said it would go standard. He said that most of the ugly was built up on the surface and only had a tiny scratch and wouldn't cause a problem. I put it back together with all new pistons and rings and all cyl honed and it purrs like a kitten. Starts good and idles, turns 6,000 by my tach and I concider it a success. I wasn't confident about the outcome as I had never done an outboard before. Had about 500.00 in it when I got done. That includes fuel pump, water pump,starter selenoid, starter gear and all new hoses. I would go for it. Good luck.................Jerry
  #4
Old November 8th, 2007, 11:53 PM
Lone Duck Lone Duck is offline
Did it run fine before you added new tank? If so check if the air vent is plugged.
  #5
Old November 9th, 2007, 03:38 AM
Joe_Navy Joe_Navy is offline
Squart a very small amount of oil in each cylinder. Then check your compression agian. The oil will seal any gaps your rings may have. If your compression test indicates higher readings. You have isolated the problem.
  #6
Old November 9th, 2007, 06:41 PM
Exclamation Re: 60 HP Mercury (1984) Loss of RPM at WOT
Quote:
The exact numbers are:
Top - 100
Mid - 115
Bot - 113
You might have overlooked them in my auto-biography!!! :-)
No, I have not performed a leakdown test. It's on the agenda...
  #7
Old November 9th, 2007, 06:52 PM
Thumbs up Re: 60 HP Mercury (1984) Loss of RPM at WOT
Quote:
Thanks Jerry, I have all the means to perform the rebuild and I even have a backup motor 115 HP Mercury 1984 model sitting at my folks home in Georgia. I have made plans to pick it up by next summer. The 60 HP has been a real challenge for my first outboard I've worked on, and I'm no mechanic! I am sure before this project is over I will be fully trained.
Thanks for your thoughts,
Dan
  #8
Old November 9th, 2007, 06:53 PM
bgbass.1 bgbass.1 is offline
Those # are not bad it should run. check likage to make sure its opening all the way. Or it could be as simple as a dirty fuel filter or dirty carb.
  #9
Old November 9th, 2007, 07:04 PM
Quote:
Yes, I do recall it seemed to be running fine. I could have picked up some debris from the new tank. I did check one of the vents on the carb and it looked ok but the other one's vent was too tight. I will most likely just go ahead & pull both carbs back out for a full inspection. To me I would think a partial clog would definitely cause issues. I just wish the compression wasn't so out of wack!!!
I'll let you know if I find anything...Thanks, Dan
  #10
Old November 9th, 2007, 07:09 PM
Quote:
I will buy a new fuel filter & inspect the carbs and let you know what I find. Also, I originally adjusted the the carbs to open all the way, which is still intact.
For a broke-in 60-mercury, what would you say should be the normally compression rate, 120psi?
  #11
Old November 9th, 2007, 07:12 PM
Smile Re: 60 HP Mercury (1984) Loss of RPM at WOT
Quote:
I will definitely try it & get back to you. Thank You for the tip!!!
  #12
Old November 10th, 2007, 12:14 AM
Another good thing to remember about compression:
How do you really know what the compression should be? There really isn't a spec for it.
Multiply the compression ratio by atmospheric pressure(14.7 at sea level)
ex. 10:1 X 14.7 = 140.7 psi
  #13
Old November 10th, 2007, 05:53 AM
If your compression is 100 or better and each cyl. is within 10% of each other your ok.Also check when warm and try a different tester have found sometimes tester off.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Sudden loss of power 1984 Merc 115 GLV502 Mercury & Mariner Outboards 6 July 27th, 2007 10:32 PM
1984 70HP power loss with no alarm cchung95 Yamaha & Suzuki Outboards 4 June 22nd, 2007 06:32 PM
1984 Mercury XR4 dizzy5868 Mercury & Mariner Outboards 0 November 1st, 2005 01:54 PM
1984 Mercury 9.8 cpahl_99 Non-Repair Outboard Discussions 5 March 1st, 2004 03:03 AM
25 HP 1984 Mercury Markie Mercury & Mariner Outboards 2 May 24th, 2002 10:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
