shibbyncsu
- Aug 30, 2007
- 10
I've got a '94 johnson OB on a sea swirl bowrider. Previous owner said he hadn't run it in a while (about a year I gathered) but said it ran fine before leaving in storage. In an attempt to get it running again, I have drained out all of the old fuel and added about half the tank of fresh gas (left it half full in case I decided to add a mixture of oil into the gas until everything is running ok). I also changed out the old oil in the reservoir with new. I inspected the spark plugs and they look good. I sprayed some stuff on them the local boat shop suggested and brushed them off and they're in pretty good shape. I also installed a new battery and wired everything back up. Here's the problem... When I turn the key on, the guages and electronics up front work but nothing happens at the engine (no sounds at all). My first thought was that a fuse was blown but checked them and they are all intact. The next thought was bad starter, but I don't know too much about them and how they work. I called an engine savvy friend and he mentioned the solenoid and something about continous power to the starter. He suggested getting a test light which I did and found that there is continuous power at what I think is the starter (the first engine component that the hot wire off the battery gets to. My question is, how do you tell if it is, in fact, the starter that is bad or how would you rule that out and what else might it be that I should start testing and ruling out? Also, is there anything else that I should be doing to "prep" the engine for the first start in a while that I haven't done?
