  #1
Old November 7th, 2007, 11:03 AM
LEKNIGHT LEKNIGHT is offline
Default bought new boat, drained stern and found...
bought my boat a month ago. took it out the next day. seemed fine, except for vibration which i thought was just because it was a old boat. also while turning while on throttle it would vibrate more and make noise. i also smelled gear oil.
i drained the stern yesterday and a fast flow of water came out followed by a slow sludge like substance. i was gonna take off the upper gear box to change the bellows. will i be able to see down if anything is really wrong. will new fluid fix the vibration if nothing is really bad in there.
p.s. my stern takes 10W-40 not gear oil
__________________
1973 Glastron v184, Ford V8 302, Volvo Penta 270 outdrive, AQ190A
  #2
Old November 7th, 2007, 11:09 AM
mtnrat mtnrat is offline
Default Re: bought new boat, drained stern and found...
Vibration may be from the prop. Is it nicked or bent? As for the sludge definitely change the fluid. Change it a couple of times actually. If the vibration is not the prop, just changing the oil will likely not make much difference, but it sure cannot hurt.
  #3
Old November 7th, 2007, 11:11 AM
Don S's Avatar
Don S Don S is offline
No, new oil will not fix anything, all it does is prevents gears and bearings from destroying themselves.
The ujoints are probably history, along with the bearings and gears in the drive.
Dissassembly and inspection is the only way to know for sure.
__________________
Don S.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
  #4
Old November 7th, 2007, 11:15 AM
wire2's Avatar
wire2 wire2 is offline
Ensign
Water intrusion means a bad seal. That alone won't cause the vibration, you have a mechanical issue in there also. In fact, the vibration probably took out a seal.
I'd open it up to see, expect to find a damaged gear or bearing. And possibly rust.
  #5
Old November 7th, 2007, 11:19 AM
thanks guys. guess i have some work to do
__________________
  #6
Old November 8th, 2007, 09:16 AM
Gary H NC's Avatar
Gary H NC Gary H NC is offline
Once you find the problem and fix it make sure you replace the bellows.Will probably need new ujoints,gimble bearing and new drive shaft.I bet you find the old bellows full of water and oil.
__________________
1981 ChrisCraft 210 Scorpion K,175 Johnson SeaHorse
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
well i bought the boat Ezrider_92356 Boat Topics and Questions (not engine topics) 6 October 27th, 2007 11:43 PM
just bought my first boat! bayarealiner Force & Chrysler Outboards 9 June 20th, 2005 02:36 PM
battery drained is it dangerous to boost with another Battery in the Boat discover Non-Repair Outboard Discussions 17 August 11th, 2004 11:38 AM
Bought my first boat! Who else has a Chrysler Boat (not engine)? ShawnQ Boat Topics and Questions (not engine topics) 5 January 20th, 2003 08:27 AM
Just bought my first boat and I need help mclay Johnson & Evinrude Outboards 7 December 19th, 2001 06:01 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
