  #1
Old November 6th, 2007, 02:48 AM
Michaelcoss's Avatar
Michaelcoss Michaelcoss is offline
Default Mercury 60 hp fuel starvation/what year?
Hi i have an older 60 hp Mercuty 3 cyl made in Belgium the serial number is and i am not sure if this the whole number 9553427. It has a split case engine cover with a red stripe on it. I am having trouble determinig the year and it seems that once it warms up it does not want to run at full throttle. It will omly allow a certain amount of power before it wants die and i have to back off.What could this be I have changed the fuel ine from the tank
to motor.
  #2
Old November 6th, 2007, 03:02 AM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
Default Re: Mercury 60 hp fuel starvation/what year?
If you want to check for fuel starvation, the below linked threads discuss this subject in great detail, which may be of help to you. If you do have a fuel starvation situation, you want to find out quickly and fix it before a lean mixture causes serious engine failure. If you eliminate fuel starvation, then you might consider other causes such as dirty carbs or ignition failure.
http://forums.iboats.com/showthread.php?t=224246
http://forums.iboats.com/showthread....ght=starvation
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #3
Old November 6th, 2007, 04:08 AM
Hi thanks for the info and the links, i will start the tedious process of elimination.Any idea on the year model?
Thanks
  #4
Old November 6th, 2007, 08:11 AM
AMD Rules's Avatar
AMD Rules AMD Rules is offline
That motor is a 1989, built in Belgium as you noted.
Warming up and slowing down could be a sign of overheating. Make certain you have a good strong cooling circuit.
Sounds like you might have a fuel pump gone bad, or a dirty carb with plugged main jets.
On your next trial, have an assistant squeeze the fuel bulb while underway to see if the symptom still exists. If it doesn't do it anymore, suspect the fuel pump.
Not a bad idea to clean and adjust the carbs anyways, if they have not been done in a while.
hkeiner pointed to some other ideas, worth checking.
Good luck.
__________________
'72 Glastron GT160 c/w '72, '84 and '86 Merc 115hp
'67 Merc 3.9hp , '70 Merc 9.8hp, '61 Merc 50hp ... The Merc Nut
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fuel Starvation? Pete215 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 June 27th, 2007 01:49 PM
Mariner15W fuel starvation, starts then stops dead, fuel in carb. ritto999 Mercury & Mariner Outboards 7 June 2nd, 2004 12:01 AM
Fuel Starvation Cubatrip Johnson & Evinrude Outboards 1 August 24th, 2003 05:47 AM
Fuel Starvation Throbbin Rods Mercury & Mariner Outboards 1 May 11th, 2003 06:12 PM
Fuel Starvation and Other ?'s billybandman Mercury & Mariner Outboards 5 March 25th, 2003 10:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
