  #1
Old November 5th, 2007, 02:55 PM
macr6 macr6 is offline
Default Anyone know how to remove or clean out a fuel tank on a '98 1750 capri?
I have a 98 1750 capri. I think the gas tank is filled with sludge or old gas or a ton of water. Is there a way to pull that thing out without removing the engine or clean it while it is installed in the boat?
  #2
Old November 7th, 2007, 11:20 PM
jddenham's Avatar
jddenham jddenham is offline
Send a message via Yahoo to jddenham
Default Re: Anyone know how to remove or clean out a fuel tank on a '98 1750 capri?
You can get a manual siphon pump at walmart or buy a 12volt 'oil' siphon made to go down a dipstick.
First flush some karosene down there and drive around some bumpy roads w/o gear in the boat.
  #3
Old September 10th, 2008, 12:09 PM
DarkForce DarkForce is offline
Send a message via AIM to DarkForce
Question Re: Anyone know how to remove or clean out a fuel tank on a '98 1750 capri?
Hey I'm a boat newb and I got a 21' 1990 bayliner cuddy capri with a 1997 115HP mercury engine and I have the same problem as the other guy above.. but I've decided that the gas tank inside the boat maybe shot to SH*% so i was gonna replace the aluminum or whatever type of metal the tank is with a plastic one myself... so i guess my question is.. is it worth doing? and if I do do it how big of a job is it really gonna be.. i got about 15gal. of gas sitting in my tank right now.. i was gonna hand pump it out.. or now reading this post buy a pump. the reason for getting rid of the tank also is because the gas and the ethanol is separating i tried to use stabilizers n stuff to bring it together but that didnt work. ive used all different types of filters n i think theres water in the tank ... the cond. of the tank is unknown since i got the boat used and i dont think the guy took care of it that great.. considering the old engine on it was broken and he covered that up by forgetting to mention it..well any help would be awesome thanks
  #4
Old September 11th, 2008, 01:40 PM
gcboat gcboat is offline
You can remove a lot of water in your fuel tank by siphoning it out. Gas is lighter than water and will float on top. Remove your sending unit from the tank, raise your bow so the fuel / water will flow to the back. Stick a hose down into the tank and siphon it out. Now, if you keep the hose as far in the tank as possible and you do have water contamination it will be the first to get sucked out. This is not the sharpest idea in the universe but using a clear gallon jug ( yea, glass ) you'll be able to see the water settling on the bottom of the jug. When no more water is coming out then you've done your job.
Needless to say, don't be a Darwin candidate and smoke.
There's a lot of other things to consider when doing this but common sense should kick in.
__________________
Life may not be the party we hoped for, but while we are here we might as well dance
  #5
Old September 13th, 2008, 11:31 AM
Smile Re: Anyone know how to remove or clean out a fuel tank on a '98 1750 capri?
LMAO.. thanks GCboat yeah I'm pretty sure smoking would be a bad idea..but I figure it would be easier to spend 10$ a gal. to have some one just pump the damn tank out..but theres still the problem of removing the tank out the boat i dont know if i wanna tackle this myself or see how much it is..if anything me and like 2 of my friends said they would help..all 3 of us have a 0 knowledge of tank removal but im sure with plenty of reading and google searches im sure i can build up some sort of knowledge as of now sounds like a pain in the *****.. Thanks for your help..and for anyone else who has some sort of knowledge to share.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
`98 1750 capri fuel gauge test? macr6 Bayliner Boats 1 July 18th, 2007 09:54 PM
Clean Fuel Tank letsgetbusy Mercury & Mariner Outboards 1 March 26th, 2007 04:49 AM
99' Capri 1750 tachometer / fuel gauge issues jkm2730 Bayliner Boats 3 August 14th, 2006 11:32 PM
99' Capri 1750 tachometer / fuel gauge issues jkm2730 Boat Topics and Questions (not engine topics) 2 June 21st, 2006 08:35 AM
How to clean old fuel tank ? philt Non-Repair Outboard Discussions 1 September 5th, 2001 10:18 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
