1994 4.3 Vortex Mercruiser, Alpha 1 outdrive, Gen II
Engine Serial OF 421280
Stern Drive Serial DF 457691
After not running for 4-5 days, this boat is a bear to start. Often takes 15 or more cranks, 10 seconds each. Three different mechanics have diagnosed the issue as "fuel boiling out of the lines" due to hot weather, claiming new fuel has to be pumped all the way from the tank.
PS: I live in southern Canada, it gets hot, but obviously southern US folks know heat better than me!
Once started, no issues...can start and stop it all day. In fact, there is really no warning that it is going to start...it just finally does!
Since I tow the boat, I always start it on muffs before heading for the water...embarrassing otherwise.
So,
1) Do you guys agree with the "boiled fuel" story?
2) Do I have an oil pressure switch issue? (understanding that the engine will not start until oil pressure is satisfied)
3) Other...almost done for this year, but next year I want this problem behind me!
Thanks
So,
Thanks
