  #1
Old November 2nd, 2007, 09:28 PM
deerhunt799 deerhunt799 is offline
Default 1987 50hp Evinrude Ignition Problems
First time poster here.
I had a problem last weekend with my motor. Turned out to be a bad coil. I changed the bad coil and it ran great for about 30 minutes. While the motor was at about full throttle, it cut out. It would only hold a rough idle after that. After messing with it for a few, I found out that it would idle and run fine by disconnecting one of the coil wires. Long story short, it would run on each coil independently (one cylinder), but the second I connected the second coil wire, it would start running rough again. So, I know each coil is functioning.
I'm guessing it could be one (or more) of three things. The power pack, stater (sp?), or the trigger. Does anyone have any suggestions on how I could test this so I don't buy anything that isn't necessary?
Thanks in advance for all your help.
  #2
Old November 3rd, 2007, 01:39 AM
angus63's Avatar
angus63 angus63 is offline
Default Re: 1987 50hp Evinrude Ignition Problems
Since both coils work but not together, I would lean towards flywheel magnets or trigger. Stator and powerpack are doing there jobs getting power to the coils, just not at the right time, it seems to me.
Good luck
  #3
Old November 3rd, 2007, 06:01 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
here's several pages of reading and testing. "http://www.boatpartstore.com/page28.asp"
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old November 3rd, 2007, 10:09 AM
Thanks for the advise! I will let ya know how it works out later today.
  #5
Old November 3rd, 2007, 01:20 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
I've looked at this thread a few times. Here's my thoughts on it. Perhaps wrong but............
There are two (2) inner flywheel magnets, one being a south pole, the other a north pole.
The timing sensor (trigger) simply takes its clue from whichever pole is passing by the sensor at the time. Bottom line here is that the sensor simply sends a 1.5v signal to whichever SCR within the powerpack is related to either the north or south pole inner flywheel magnet..... meaning the sensor (trigger) is okay.
This leaves the problem area, if both coils are firing at once or are erratic, to be either the flywheel magnets or the SCR switches within the powerpack.
Take a close look at the inner flywheel magnets. Many of them are held in place via some kind of epoxy. That material has been known to melt somewhat which allows the magnets to change their critical position which in turn causes the engine to run erratic..... or not at all. If this condition has taken place, it should be easy to determine, quite obvious.
You can check the magnets to see which is south or north by holding a compass near the slots, BUT not too near as that would magnetize the compass for some time...... the compass if magnetized wears off in time.
If the flywheel inner magnets are indeed where they belong and nothing seems to be amiss in that area..... nothing torn up, no metal filings, etc, and all of the related wiring is frayed, shorted, or missrouted, I'd strongly suspect the powerpack.
When time permits, visit my store (copy/paste) at: stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 DT-175 ignition problems kuder Yamaha & Suzuki Outboards 4 June 4th, 2005 08:20 AM
1987 force 50hp wot running problems John5421 Force & Chrysler Outboards 7 October 10th, 2004 05:47 AM
Force 50hp / 1992 / ignition problems glljansen Force & Chrysler Outboards 12 August 1st, 2003 09:04 AM
1987 50hp johnson lower unit problems fpctim Johnson & Evinrude Outboards 20 January 3rd, 2003 01:27 PM
Johnson v6 150hp 1987 ignition problems? Andreas_typhoon Johnson & Evinrude Outboards 1 June 20th, 2002 12:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
