  #1
Old November 2nd, 2007, 01:44 PM
goodtimes goodtimes is offline
Default 1987 175HP Evinrude exhaust cover removal??
My friend got a 1987 175HP Evinrude with water in the starboard side plugs. I did a compression check and all 6 of them came out around 85psi. So... I would think its the exhaust gaskets. I have read the Seloc manual and it states that i might need some heat on the bolts to get them out. Should I start the engine and let it warm up a little to get the exaust a little warm? Might be easier to get the bolts out this way. Any tips or tricks to get these bolts out without breaking them?
  #2
Old November 2nd, 2007, 04:08 PM
emdsapmgr emdsapmgr is offline
Default Re: 1987 175HP Evinrude exhaust cover removal??
These head bolts are pretty good size and have fairly low torque. They should come out without much problem, unless this is a saltwater engine. Try going a quarter turn on each to see if they will all loosen. The compression on these engines doesn't run real high anyway-you're only 10 lbs low and that could be the test rpms or gauge variance. If you don't find anything with the head gasket, check the exhaust cover.
  #3
Old November 2nd, 2007, 06:00 PM
I'm pretty sure it's the exhaust gasket since the compression was even on all 6 cylinders.
  #4
Old November 3rd, 2007, 08:14 AM
If you're going into the exhaust covers, check the inner cover for porosity. Sometimes the casting will develop "leaks" and when under high pressure, will force water back into the exhaust and the lower cylinders. Lay the cover flat and put a small amount water on it and check to see if it leaks through the backside. You can also use a bright light to check for porosity. When reinstalling, follow the service manual specs to get the bottom of the cover flat with the bottom of the block. Also, I'd retorque the cover bolts after a few hours use.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude 235 exhaust cover imported_ricardo Johnson & Evinrude Outboards 2 June 25th, 2007 11:36 AM
60hp evinrude exhaust cover gasket mopar1970 Johnson & Evinrude Outboards 4 September 8th, 2006 02:59 PM
Need Evinrude exhaust cover gaskets Arisaka Johnson & Evinrude Outboards 1 August 30th, 2006 02:11 AM
Exhaust Cover Plug won't come out - 93 Evinrude 40hp Mark42 Johnson & Evinrude Outboards 18 May 24th, 2006 05:14 PM
7.5 hp Evinrude exhaust cover bolts old one Johnson & Evinrude Outboards 2 May 10th, 2002 08:54 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
