Texasbikers
- Sep 12, 2007
- 21
1988 Galaxy, I followed advice from and earlier post, trying to get the shine back on this ol girl.
I'm working on the dark blue stripe on the side. Bad oxidation, I wet sanded, 400 grit, then 800, 1000 and 2000. I power buffed with Meguiars deep cut rubbing compound and it does SHINE, haven't done the glaze yet. I've only done one side so far, the finish is glossy, I can see my reflection but, the blue is not a solid blue.
It looks kinda like a snake belly pattern, splotchy, light and dark colors, not a solid uniform patter. DId I not sand far enough?
If not, can I used a smalll hand size orbital sander with dry sand paper to get down to solid blue? What grit should I go with to get to solid blue. Then can I wet sand back out from there?
Also, is going to 2000 overkill?
Man my arm is tired...
Thanks guys!
Thanks guys!
