Interesting situation;
Have an issue that when I plug in the lanyard I do not get the 2 beeps, gauges do not come on and ski will not turn over. Thought I had an MPEM issue. Took to the dealer and they said they could not communicate to the MPEM. Have pinned out all of the harnesses, replaced post.
I pulled the 15 AMP fuse in the relay box while the lanyard was on the post and the ski came to life. It started and when on the lake runs perfect. If I pull the lanyard and reinstall, the ski will not turn on the gauges and start unless I pull the 15amp fuse and reinstall (this is the fuse that provides 12V to the MPEM).
I have since added a switch to break the circuit to the MPEM when I want to ride the ski and it will start and run perfectly. Talked to the dealer and they have no idea and was amazed that I even found how to make it function in this way. I am fine using it this way but wondered if anyone has ever heard of this scenerio before. It is for sure not a ground or power issue as I have ohm'ed out and confirmed that every circuit has proper continuity.
Thanks for any ideas
