Part Number - 1960 Evinrude 18 hp Upper Crankcase Seal
Does anyone have the correct part number for the upper crankcase seal for a 1960 Evinrude Fastwin 18 hp? I was given the part number 305987, but it turns out that it is way too small. Its an expensive seal and I don't want to buy the wrong one again.
Re: Part Number - 1960 Evinrude 18 hp Upper Crankcase Seal
Turns out its the seal I got has the right dimensions for a 305987, unfortunately my motor doesn't take that seal. Its OD is 1 3/8", but the one I need is 1 7/16". Perhaps mine is a hold out from the 1959 model year, which I understand had a different seal. guess the only thing left is to try the older seal. The plug on the motor says 15032, which is a 1960 so I'm not confused about the year.
