drive shaft is it strait
Benny1963
have drive shaft on lower unit of 150 evin is there a way to check to see if it is strait without removeing it from lower unit mech said i may or may not
have bent when removeing it
thanks benny b
F_R
Re: drive shaft is it strait
How in blazes did you remove it? Those things should be extremely difficult to bend. I'll bet you couldn't bend it if you tried to. Maybe if you run over it with a truck.
Benny1963
hi fr well i had to take motor off boat and atach at power head
used hoist to put in a bind i dont think its bent but boat mech i called wanted to replace drive shaft without even looking at it
shaft seams indestructible im going to install lower and give it a test run thanks fr
benny 1963
