  #1
Old October 30th, 2007, 03:50 PM
Deanrt's Avatar
Deanrt Deanrt is offline
Default Loss of power 35 HP Evinrude
Hi all. I have a 35 as the title says, anyway i had the thermastat changed and it ran ok the first time out but seemed to run a bit hot. I ran it for a total of maybe ten min. I have since then been a little reluctant to take it out. Well i did yesterday it seem to run ok but i can only get it up to 12 or 13 mph where before i would get 23 or 24. When i ran it i had a 200 degree temp stick and it never got there. Could damage have happend at less then 200? or could it be something else. There is one other thing there is a small linkage for the carb that the mech took off to use the throttle from the engine, and i cannot figure out how that thing goes back on, could it be that? Any ideas and imput will be appreciated. Thanks, Dean
  #2
Old October 30th, 2007, 04:50 PM
bgbass.1 bgbass.1 is offline
Default Re: Loss of power 35 HP Evinrude
If its a small rod curves out at top and bottom it goes into 2 plastic keepers. what year motor? and can you get a pic.
  #3
Old October 30th, 2007, 05:07 PM
iwombat's Avatar
iwombat iwombat is offline
I'd bet dollars to donuts that's your problem. I'd also not run that motor until you get it figured out. If it's the linkage between the two carbs, your bottom carb is not opening up. That also means half your engine isn't getting any lubrication.
  #4
Old October 30th, 2007, 09:21 PM
Deanrt's Avatar
Hey you guys thanks for your replys. #1 this is a '76 35 hp. #2 it has only has one carb.. I have taken a couple of pics and i will try n figure out how to post em. Cool the pics are there. When i connect the two ends with the motor running it dies!
  #5
Old October 30th, 2007, 10:07 PM
HighTrim's Avatar
HighTrim HighTrim is offline
You may need a variety of carb adjustments, including throttle and choke linkage, solenoid adjustment, throttle cam adjustment, etc... Do you have a manual, if not, they are a good investment. It looks as if the throttle cam and linkage are unhooked.
__________________
Chris
  #6
Old October 31st, 2007, 08:06 AM
Hightrim is right need to readjust carb and linkage definatly need manual. it looks like something is missing there should be plastic keepers in holes to hold rod.
  #7
Old October 31st, 2007, 02:25 PM
Deanrt's Avatar
Thanks again. I do have a manual. And yes there is a little plastic keeper for the end of the linkage that isn't connected. The reason for that is when i hook it up it pops off probably just old and worn. Took it to the shop yesterday to have em hook it up, they did and off to the river for 'another' test run, well same as last. Took the cover off and thats how the linkage was, in the 1st pic. It just seems to be to tight of a fit for that to stay in without the plastic popping out!
  #8
Old October 31st, 2007, 05:26 PM
60 grit sandpaper 60 grit sandpaper is offline
a nylon keeper thing snaps onto the throttle cam.Pointed tip cut in the middle snaps into hole on cam.Linkage snaps into nylon keeper.Linkage slides freely in keeper untill bent end of linkage hits keeper.The linkage then opens throddle.This happens when the choke is activated.Once choke is open this linkage slides releasing the throttle.
  #9
Old October 31st, 2007, 05:30 PM
It's only use is to give some throttle at start up when choked.
  #10
Old October 31st, 2007, 07:47 PM
Deanrt's Avatar
Thanks 60 grit, it makes complete sence, however when i hook it up just like you explain, with any movement of the throttle it pops off, like in the first pic. Its like there is not enough space for it. I dont know it sure seems simple but its got my number
  #11
Old October 31st, 2007, 08:17 PM
When throttled the link should stay stationary. the nylon keeper moves with the throttle.Is something bent?Are both ends of the link free to pivit easily?Keeper pivits in hole of throttle and the other link end is bent in a hole.These parts are lined up nicely and sliding is smooth.Something must be bent out of alignment,binding,or keeper is worn so much.That's all I can think of.
  #12
Old October 31st, 2007, 08:20 PM
This isn't fixing the original problem.Hopefully someone else will.
  #13
Old November 2nd, 2007, 12:38 AM
Deanrt's Avatar
Thanks again 60 Grit. Nothing seems to be bent and the plastic keeper is pretty worn. Does the linkage in the first pic look to you to be on right? Ive not tried to put it on the othe way, just a thought.
  #14
Old November 2nd, 2007, 08:14 AM
Yes it's on right.There is no keeper in the picture.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 Evinrude 70 surge in power/loss of power huntingjustinlouise Johnson & Evinrude Outboards 6 April 8th, 2006 05:36 PM
power loss evinrude vro 40 peter52 Johnson & Evinrude Outboards 5 March 30th, 2005 11:27 AM
87' 70H.P. EVINRUDE VRO LOSS OF POWER JoesBoats Johnson & Evinrude Outboards 0 July 28th, 2003 06:32 AM
9.9 evinrude loss of power John5421 Johnson & Evinrude Outboards 2 July 26th, 2003 03:45 AM
6HP Evinrude loss of power work4bait Johnson & Evinrude Outboards 1 August 27th, 2002 10:45 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
