The engine starts readily and runs at high speed but I can't get it to run at low speed. I have tried to adjust the throttle cam synchro. and thought that would fix it but it really had no noticeable effect. It seems to surge or hesitate as I throttle to high speed.
I have been working for a few weeks to restore this old motor. I started by replacing the impeller and it now pumps water. I have removed and cleaned the carburator and get spark at both plugs. I have replaced the fuel lines (they were cracked), lower unit lube, spark plugs, set the points at .020.
I also notice that the insulation on the coils is cracked. Could that be contributing to the problem? I was hoping not to have to replace them and I am getting good spark at the plugs.
Any help would be appreciated.
