Tommytwotone
- Sep 11, 2007
- 2
I have a 1979 40 hp Johnson outboard. I thought I had a problem with the return spring on the bendix of the starter because the bendix gear was jumping up into the bottom of the flywheel. It is now looking like the starter motor vibrates which causes it to turn and as it turns it is pushing the bendix gear up into the flywheel. I had the starter rebushed last spring. I can run a little over half throttle but when I start giving it more gas the gear starts ringing against the bottom of the flywheel. I'm afraid that one of these days it's going to get caught in the flywheel and I'll have a major melt down.
Any ideas on what I should do? I've cleaned and lubed everthing and everthing works just fine other than this vibration thing. I even put a new prop on this year thinking it would change the resonant frequency. I'm stumped.
