lower unit jammed
aircraft1
New to board need some help, lower unit will not release/ 1975 85 horse evenrude. All bolts are out six in total four bolts out on lower unit as well as bolts at rear of lower unit one under trim tab and the one forward from trim tab. As well I have removed the shift fork at top of shift rod. The lower unit is separated about .100" but is not separating at right side. Am I missing something? I do not want to forse it.
thx
aircraft1
bgbass.1
Re: lower unit jammed
it should come out it sounds like you have all bolts out try tuning fly wheel to see it will release if not rubber mallet may help free it
aircraft1
thx for the info I hpoe to solve this issue going fishing in two weeks I'll give it a try. If I hit it to work it out could I cause any internal damage?
