  #1
Old October 24th, 2007, 10:44 PM
bigsidster bigsidster is offline
Default 1973-mercury 500-50hp Tach question?
I have a 1973 Mercury 500-50 hp-2 stroke---4 cylinder outboard.I have a Power Fist Electronic LED Tachometer 0 to 8000 rpm.It is a TRISCO brand.It is a 12VDC and has a setting button to set it for 4,6 or 8 cylinder.Has 5 wires coming out of it.BLACK is ground to -negative battery terminal,RED is tach power wireto ignition ON (run) position.ORANGE is memory LED and goes to battery +positive.WHITE is night light and goes to light switch.GREEN is the Tachometer signal wire and connects to signal source.
2 questions?
Can I install this tach and use the "4 cylinder setting" and get a correct reading?
If I can,where do I connect the GREEN tach source wire?
Thanks for any help you can give me.
  #2
Old October 25th, 2007, 01:01 PM
Default Re: 1973-mercury 500-50hp Tach question?
Please---somebody with tach knowledge please help.
  #3
Old October 25th, 2007, 03:31 PM
bhile's Avatar
bhile bhile is offline
That sounds like an automotive tach. It will not work properly with an outboard. 2 cycle vs 4 cycle. Input for the tach is a gray wire in the harness.
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #4
Old October 25th, 2007, 05:03 PM
pman7 pman7 is offline
I can't confirm whether or not you have an automotive tach.
When you get the right tach your sender wire should hook to either of the leads (yellow wires with red stripes) on your rectifier that come from your stator/alternator. There is a third lead on your rectifier that has a red wire and that is the only wrong wire.
There is no wire in a stock wiring harness that hooks to these leads. You can rig the wire through your harness but most people run the sender wire straight to either of those yellow wire leads on the rectifier. The rectifier switches the current produced by your stator from AC current to DC current and sends it out through the red wire side of your rectifier.
The marine type tachs read the number of pulses from your stator. Since your tach says cylinders and not pulses I would speculate that you do indeed have an auto tach as the previous poster said.
ps: The information I gave you is for my 71 Merc500. I believe your setup is the same. I'm not certain but I think it is so.
  #5
Old October 25th, 2007, 08:14 PM
Thanks for responding PMAN7.Looks like it is an auto tach so I wil have to trade it for an outboard tach.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
94 Mercury + Tach question ctangler Mercury & Mariner Outboards 3 August 6th, 2007 07:10 PM
50hp mercury (another Question?) b75nweav Mercury & Mariner Outboards 8 February 26th, 2007 07:09 PM
mercury tach w/ 50hp evinrude 90LIMITED Johnson & Evinrude Outboards 2 May 16th, 2006 09:05 AM
Tach question for Mercury 650 JollyBFD Mercury & Mariner Outboards 1 June 7th, 2005 12:47 PM
1973 mercury 85 tach pole setting ljraffray Mercury & Mariner Outboards 19 November 11th, 2001 05:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
