  #1
Old October 24th, 2007, 09:36 PM
Demolitron Demolitron is offline
Default 1974 Evinrude 115 Reverse Problem
Hello All,
I have a 1974 Evinrude 115HP 115493B engine. I have a problem with reverse gear. When I put it into reverse a couple of things happen.
1) The control shakes back and forth and I've looked under the cover and the bell crank on the shift level is bouncing up and down. It also makes a very unpleasant noise. I adjusted the cable trunion and was able to get it where it would fully engage, albeit with a little bit of "grinding" (this isn't exactly the kind of noise I hear) It sounds just like the clutch dog teeth are bouncing out of the gear slots... Also, I had to adjust the shift cable so there is an extreme amount of pressure built up. Basically, the bell crank is back as far as it will go but the shift level up at my control box has about 25% more travel. For the last 25% the cable ends up flexing. I also checked to see if the bell crank was hitting anything under the engine, like if the shift rod was miss-adjusted, but it is clear.
2) Once in gear I can't apply even the slightest amount of power before it starts popping and grinding again. It’s enough to do small maneuvers however.
No problems with forward gear, yet.
Also, how do I tell if I have manual shift or hydraulic assisted shift? My Seloc manual shows that this model had three different kinds of shift (Manual, Hydraulic, and Electric). The factory manual I ordered from EBay shows that I should have the Hydraulic shift. (It also says I should have power trim and tilt *But I KNOW i don't have that*) The front cover shows it as Model: 115493B I got my model number from the transom bracket, so I think it is accurate.
Thanks for any information!
  #2
Old October 24th, 2007, 09:55 PM
F_R F_R is offline
Default Re: 1974 Evinrude 115 Reverse Problem
You have the power hydraulic assisted shift. Your clutch dog and reverse gear are toast. Not accusing you of anything, but it is usually caused by "easing" it gently into gear. Exploded view parts list at http://epc.brp.com/default.aspx?brands=ej&lang=E
  #3
Old October 24th, 2007, 10:12 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
agree, time for a lower unit rebuild or a donor lower.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old October 25th, 2007, 03:37 AM
F_R F_R is offline
There is a remote possibility that it is a hydraulic problem, but that is small comfort--still needs major work.
  #5
Old October 25th, 2007, 12:48 PM
Thanks for the information. I bought this boat used and the previous owner did other "things" that make me question his sanity.
Is it safe the assume that, because forward is working well, that my forward gear is okay? From my service manual it seems like it would be much more work to remove the forward gear and replace it as I would be removing the drive shaft, pinion gear, oil pump, etc... Plus it seems like the FWD gear is VERY expensive.
Also, I imagine that I should put all new seals in it. Does the Sierra Seal Kit 18-2692 apply for my engine, and is it a quality unit or is there another one someone would recommend?
Does someone know of a source where I could buy a new Lower, just in case...?
Thank You.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New Problem with 1974 50HP Evinrude mstone1968 Johnson & Evinrude Outboards 2 June 6th, 2007 12:27 PM
1974 85 hp evinrude idle/advance problem bandanaman Johnson & Evinrude Outboards 6 June 9th, 2006 07:36 PM
1974 evinrude 70 hp spark problem HELP! dlbagem Johnson & Evinrude Outboards 2 August 23rd, 2004 06:11 AM
Mercury 850 (1974)/ Reverse problem texas15 Mercury & Mariner Outboards 3 June 16th, 2002 12:00 PM
Mercury 850 (1974)/ Reverse problem texas15 Boat Topics and Questions (not engine topics) 1 June 15th, 2002 05:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
