Re: Why replace my Impeller?
The water pump impeller is th heart of the cooling system for your motor. It's a regular maintenance item and should be replaced on a regular basis. Without the pump working, the motor will overheat resulting in cylinder damage. Motors that have been stored for long periods of time need the pump replaced. The impeller 'arms' take a set and don't pump water well. Address the water pump first, everything else as needed.
BTW, while you asked a good question, you also asked the same question in your other post. Try to keep your questions in one post, it lets folks follow your progress and prevents folks from jumping around trying to address your specific motor issues.
