125hp mercury 2 cycle 4 cylinder rpm problems
Today as i was going fishing my merc outboard would not run above 2700 rpm's while under power. In fast idle i can hit 4000 rpm's easily(did not want to go higher while not under way). Two days ago while fishing, i had no problems! This motor is "on-demand" cylinder displacement, will run on two cylinders at low speed and run on 4 cylinders at higher rpm's. Any sugestions or comments. Thanks.
