25hp Evinrude Sportster starting problem
jhedgeti
Not sure what year the 2 stroke 25hp Sportster is. The spark plugs spark- very little gas gets to the plug- compression feels good- tank is properly vented. It will not start or even give a hint of starting. Could the gas line be blocked ?? If so what can be done? Is it the fuel filter?
Thanks for any help Jack
tashasdaddy
Re: 25hp Evinrude Sportster starting problem
more history, model number, has it been sitting a couple of months or years. last service done to it. go to the engine faq forum, read outboard won't start, and awakening a sleeping outboard.
samo_ott
As well as what TD said, try spraying some 50:1 premix in the carb and see it it catches at all. If so then you have carb probs. If not you have ignition probs.
BF
I have a 1970 25 hp sportster... when I first got mine, I found out the spring that activates the choke butterfly on the outside of the carb had a notch worn into it, so would catch and the choke would usually not work properly (but occasionally it slide over the catch and it'd work ok)...
I took the carb off, took that spring off, and unwound it 1 coil so that it was smooth at the point that it rubs on the butterfly cam... the choke's been working well for ~ 5 years now. When I found this, I figured it must be a really common problem on these oldies, but I've never heard of anyone else having it.
Anyway, it's something for you to check. Good luck.
jhedgeti
The serial number for this engine is 25103S - E02944. That is the number on the plate which is on the lower shaft. How does this number help?? Where can I find out what the number means?
Thanks - Jack
cr9c1
You have a 1971 Evinrude 25 HP
JB
Go to the Engine FAQs, Jack. Do the "Outboard won't start" troubleshooting.
Let us know what you learn.
Good luck, and welcome to iboats. :)
