I'm totally new to boating, and I've already put more than 40 hours on my boat (volvo penta sx 5.0 GL). The boat is currently at 170 hours.
Can someone recommend a shop that will service a volvo penta sx?
An internet friend recommended the following services:
Fog engine, drain engine block, manifolds and exhaust bellows, refill with bio-degradable antifreeze, greese steering, throttle and shift cables, coat engine with anti-corrosive spray, remove outdrive, grease outdrive u-joints and gimbal bearing, change gear oil, remove prop(s), check engine alignment, reinstall outdrive, change engine oil, oil filter and fuel filter, replace impeller.
