i386
- Aug 24, 2004
- 3,548
I need a little help troubleshooting this problem...
Once I get the boat on plane for about 1 minute the RPMs keep going down as if I'd let off the throttle. I have found that if I spray a little premix into the carb as this is happening it revs back up. The bulb remains firm and I have checked my hoses for holes and poor clamping meaning I don't think I'm losing my prime. Once I get some fuel to it, it's not difficult to start. Squeezing the bulb doesn't seem to be as effective at keeping it running as spraying a little premix into the carb. I did remove the fuel pump. I'm not sure what I'm looking for but the gasket, the part with the little reed valves in it (not to be confused with THE reeds) and the diaphram all look to be in great shape. I have not touched the carb yet.
I personally think there's something wrong in the carb. I'm thinking about just ordering a fuel pump and carb kit and be done with it. What say you?
Thanks in advance!
Thanks in advance!
