  #1
Old October 21st, 2007, 09:17 PM
Jimbob40 Jimbob40 is offline
Default 1973 Evinrude 115 hp Ignition dilemma
This motor runs good when first started then after increasing rpms I watch the voltage increase a couple volts as it should to charge battery. But when I return to idle and the charging voltage drops I get a cough and the engine quickly dies out. I have replaced stator and rectifier and was wondering where to go from here. I am watching this voltage movement on a engine analyzer as the volts drop engine dies. It starts right back up and is ok at idle and when revved up again and then back to idle volts drop she dies. I am skunked! I am thinking powerpack problem, but would like other opinions. Help! thanks
  #2
Old October 21st, 2007, 09:22 PM
F_R F_R is offline
Default Re: 1973 Evinrude 115 hp Ignition dilemma
The powerpack is not connected to the battery voltage. It runs off the charge coils, not the alternator coils. Both are on the stator.
  #3
Old October 21st, 2007, 09:47 PM
Its a brand new stator. But the problem is the same as it was before I changed it. $300 bucks wasted so far. ny ideas what else?
  #4
Old October 22nd, 2007, 05:57 AM
ok figured it out! First the temp assembly wires were bad where they go into the head and probably sending a ground to the terminal...fixed that. Then it ran better and I was able to set idle timing to 5 deg and then I set carb sync and it just idled beautifully in the tank for an hour after restarts, revs, in gear out of gear ect. Personaly I think the rpms have to be high enough to keep the charge circuit working properly. Along with the bad wire, my idle speed was too low and when I lowered startup lever it ran too low for the charge circuit to work hence creating a cough and dying. Anyway she's ready now. Ky Lake here I come!
jimbob
  #5
Old October 22nd, 2007, 06:18 AM
Indymike Indymike is offline
Here is a link to a troubleshooting guide.
http://www.rapair.com/media/Troubles...ide%202006.pdf
You might also look at your timer base and make sure that it rotates as it should. The vinyl sheath that protects the conductors connected to the timerbase can become very stiff ,not letting the timer base return to idle position.
__________________
Mike
The Journey begins
Journey II
  #6
Old October 23rd, 2007, 05:19 AM
Thanks for the link...good info!
  #7
Old May 29th, 2009, 11:16 AM
drno_503 drno_503 is offline
hi ,, my 115 omc v4 in jet boat overheated and engine died
replaced ignition pack that drive 4 coils
all ohmmeter and peak voltage seem to b ok
charging voltage at start speed 170 +
4 trigger voltages at each lead
NO SPARK
over tem sensors located in heads are disconnected
have tried to remove flywheel with correct puller AND accetline torch
wont come off
any suggestions
ps this boat had water in engine well for years before i bought it
in florida,,, before it overheated it ran + 28 mph
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Ignition Problem - 1973 6h.p. Evinrude nedarb2 Johnson & Evinrude Outboards 18 April 23rd, 2006 06:18 PM
25 302 A ,evinrude 25hp 1973 right ignition kit? fishfighter Johnson & Evinrude Outboards 2 March 2nd, 2006 07:43 PM
1973 6hp ignition question phatmanmike Johnson & Evinrude Outboards 4 April 12th, 2004 04:29 PM
Suzuki or Evinrude dilemma ?Need Help ! xxwulvexx Non-Repair Outboard Discussions 1 December 3rd, 2003 04:28 PM
ignition dilemma ! way2goace Force & Chrysler Outboards 2 August 14th, 2002 01:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
