I have a 3-cyl 50hp Mercury that was running great all summer. Went to go out duck hunting and ran it up the night before and it starts and runs with the choke/fast idle set up but after it warms up and I set the fast idle lever to normal in the neutral position it stalls out and doesn't want to stay running. I cleaned out the fuel filter,fuel pump, checked the enrichment solenoid valve and the gas tank,fuel line,primer bulb and all are ok. I even got fresh gas and changed the spark plugs too. I have been using stabilizer in all my gas even before the ethanol and never had a problem. I also check the CDMs for all 3 cylinders and they are good too? Any suggestions would be greatly appreciated.
