  #1
Old October 20th, 2007, 08:30 PM
Osprey Osprey is offline
Default Aging 1995 - Grady 208 Adventure
I have owned a 1995 Adventure 208 for about 3.5 years now. Its a great boat which in many respects I'm completely satisfied with and in most respects is very well built. But must say I'm not impressed with several design/build aspects of the boat.
A few examples:
1. Fuel tank failed due to factory install issue. Metal staples were used to fasten rubber padding strips to 2x4 wood cross braces that hold the tank. Several of the staples from day one had made contact with the top of the fuel tank. Mix in a little saltwater with the contacting unlike metals and a corrosion hole in the top of the tank was the result.
Also the tank sat on top of two very thin rubber strips which were not glued of fastened to the boat. As a result the bottom of the tank had rubbed against fiberglass creating another area of wear and corrosion on the bottom of the tank.
Replaced with new fuel tank and had to rework how it was mounted.
2. Plastic thru-hull fittings. These should be outlawed. Likely fine for the first few years but eventually almost guaranteed to become a saftey issue. The plastic ages, becomes brittle and they crack and/or fail completely. If at or near the waterline this will result in a little or a lot of water in the boat. Replaced all with stainless.
3. Bildge bulked drain pipes 3/4 or more filled with resin at the factory. The only pvc drain pipe that allows water to pass from the central fuel tank compartment back to the bilge area in the stern had been almost completely glassed over with resin at the factory. Another smaller pvc pipe which drains the cabin floor area was also nearly glassed over at the point it entered the bildge.
Sure glad I bought a "high-quality" used boat. Would hate to see what low end would be.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aging aspeck Dockside Chat 4 April 19th, 2006 10:41 AM
The Aging Process !!! scrapper Dockside Chat 7 March 15th, 2006 08:47 AM
Two stroke oil in bilge jams bilge pump switch. - 1995 Grady White story continu Osprey Boat Topics and Questions (not engine topics) 2 July 4th, 2004 07:56 PM
Aging motors 10point1 Non-Repair Outboard Discussions 2 July 20th, 2003 08:05 PM
Suzuki AGING SPOONS Yamaha & Suzuki Outboards 4 February 13th, 2002 03:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
