  #1
Old October 20th, 2007, 03:45 PM
Ken Corkey Ken Corkey is offline
Thumbs up Yamaha 40 HP carb settings
Anybody?! What are the settings for the needle valves on a 2000 40hp Yamaha? How many turns from the closed position?
  #2
Old October 21st, 2007, 08:54 AM
bgbass.1 bgbass.1 is offline
Default Re: Yamaha 40 HP carb settings
if i remember right go 2 turns and then adjust from there
  #3
Old October 21st, 2007, 09:38 AM
rodbolt rodbolt is online now
depends on year model and number of cylinders and 2 or four stroke.
seems yamaha actually made more than one 40 horsepower model. imagine that.
  #4
Old October 21st, 2007, 09:42 AM
my bad
00-05 carbed 4 strokes have EPA carbs . that means your supposed to count the turns in and record it.
however if you will start about 1 3/4 it will get you close.
if its a 2 stroke model set the pilot screws at 1 1/2 from seated.
  #5
Old October 21st, 2007, 05:43 PM
Thanks
  #6
Old June 5th, 2008, 04:13 PM
capf capf is offline
2002 yamaha 4 stroke, 3 cyl, 3 carbs, cleaned carbs engine starts and runs well at idle, will not go over 2000 rpm, stalls at about 2000. everything looks ok inside carbs, plugs are new. Looking for suggestions. Tried boring out low speed jets little bit and that seemed to help starting and low speed, then tried boring out main jets and that was a mistake. waiting for new, stock jets. Fuel has some ethanol mix, owner has added something supposed to compensate for the ethanol.
  #7
Old June 22nd, 2009, 10:25 AM
cprince07 cprince07 is offline
i have a 2000 Yamaha 40 hp (f40esry) with the same problem. It sat for 1 year. i replaced the fuel tank, both fuel filters,removed the carbs and cleaned them and replaced the plugs. It idles fine but when i i give it the gas to go on and take off it dies, when it does die it will started right back up and idle perfect. It acts like to me it is starving for fuel under a load,fuel pump maybe?? Any help would please?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Carb settings C144 Johnson & Evinrude Outboards 1 September 27th, 2007 08:15 AM
anyone know carb settings for 1993 OMC Cobra 5.0 HO with holly carb Adam13 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 August 24th, 2005 07:45 AM
Help with carb settings PLEASE Darryl34 Mercury & Mariner Outboards 1 April 6th, 2004 09:58 AM
Yamaha 40 E Carb settings N9NZH Yamaha & Suzuki Outboards 1 June 17th, 2002 05:50 AM
settings of yamaha carb gerke Yamaha & Suzuki Outboards 2 June 15th, 2002 12:29 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
