  #1
Old October 19th, 2007, 01:48 AM
piggy piggy is offline
Default Questions on rebuilding pontoon
Installed Alm. A-frame motor mount will have to put new wood on back would 3/4 in. marine grade plywood (two pieces glued together,1 1/2in. total, then painted and with alm. bolted around edge work o. k. Also would using same plywood for deck on galv. stringers be o. k. When mounting motor how deep must motor be, water line at or just above first fin above gear case or must water pump be under water. Fresh water use only and with tilt and trim. Thanks for any help.
  #2
Old October 19th, 2007, 01:56 AM
desi desi is offline
Default Re: Questions on rebuilding pontoon
Probobly overkill on the 11/2" deck, how thick is the metal that is galvanized for stringers?
  #3
Old October 19th, 2007, 02:00 AM
sorry will only use 3/4 in. on floor. Also only up to 30h.p. motor with t&t
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Force 85 rebuilding questions... newbie4life Force & Chrysler Outboards 12 June 2nd, 2008 04:01 PM
Rebuilding - What Questions should I ask? crankit Johnson & Evinrude Outboards 1 April 29th, 2005 04:39 AM
Rebuilding Pontoon Boat DD460 Boat Restoration and Building 0 July 12th, 2004 11:16 AM
4 Stroke OB's Rebuilding Questions Dhadley Non-Repair Outboard Discussions 30 May 12th, 2003 12:41 AM
Evinrude VRO pump rebuilding questions Luna Sea Johnson & Evinrude Outboards 1 July 26th, 2002 04:16 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
