  #1
Old October 17th, 2007, 08:50 PM
Nightrider069 Nightrider069 is offline
Exclamation 110 Evinrude fuel problems
I have suction problems when I get below half tank, the pump cant suck the fuel out of the tank?? I have rebuilt the pump same problem changed the filter, new connection to the motor, still nothing. It will run fine on an external tank. My question is if I can run an external pump inline to solve this problem.
  #2
Old October 17th, 2007, 09:23 PM
F_R F_R is online now
Default Re: 110 Evinrude fuel problems
Fix the problem, not the symptoms. Is there a bad anti-siphon valve in the tank? How about a filter that may be restricted? How about the pick-up tube in the tank? Does it go clear down almost to the bottom? How about, does it have a hole in it half way down? There has to be something wrong if it will run OK on a portable.
  #3
Old October 17th, 2007, 09:27 PM
Well I looked at all of that and there is no hole in the pick up tube and yes it dose go to the bottom and the sending unit works. I also have a clear filter and I can see that there is no air in the system. so what is next??
  #4
Old October 17th, 2007, 09:28 PM
HighTrim's Avatar
HighTrim HighTrim is offline
What about the anti syphon valve as FR mentioned.
__________________
Chris
  #5
Old October 17th, 2007, 09:37 PM
the only one is in the primer bulb, and it is new??
  #6
Old October 17th, 2007, 09:39 PM
Solittle Solittle is offline
First a BIG WELCOME!!
Me thinks your best bet would be to solve the problem that you have rather than bypassing it. From your description you have a problem with the pick-up in the tank and/or the tank is not properly vented giving you a vapor lock.
You could use an external pump but they are electric and quite expensive. My boat came equiped with one. When it went south the replacement was over $200.00.
  #7
Old October 17th, 2007, 09:45 PM
HighTrim's Avatar
Your anti syphon valve is located at the tank, but I understand your thinking by saying your bulb. It is usually located where the fuel line goes from horizontal to vertical. I would replace it first.
__________________
Chris
  #8
Old October 17th, 2007, 09:52 PM
Unhappy Re: 110 Evinrude fuel problems
I had that apart a month ago and it was working fine???
  #9
Old October 17th, 2007, 10:01 PM
HighTrim's Avatar
The only things that I can think of that would cause that problem are the ones listed by FR, might want to go over them again. How do you know the anti syphon valve was ok by the way? I think if it is vented properly, the filter is not clogged , the pick up is clear and the hose is laying on the bottom of the tank, it would point to the anti syphon unless anyone has any other ideas.
__________________
Chris
  #10
Old October 17th, 2007, 10:07 PM
well when I had that out of the fuel tank I was abel to blow air one way but not the other so I would assume that it is working. The manual only shows an external tank being used? I am thinking tha an 1988 pump will fix the problem since the engine is an 1986.. so what is next??
  #11
Old October 17th, 2007, 11:01 PM
Let's go back to the beginning. You said that it is OK until the tank is half empty then it runs out of gas. That should be a clue. There is something wrong with the pick-up tube in the tank, or the tank is not vented.
No fuel pump replacement can cure that.
  #12
Old October 18th, 2007, 06:43 AM
when this happens I can squeze the primer bulb and the problem is fixed until I burn that gas off.
  #13
Old October 18th, 2007, 06:45 AM
emdsapmgr emdsapmgr is offline
Is this a built-in tank or a remote 6 gal tank? Are you sure the gauge on the tank is ok? Check the seal at the top of the fuel pickup where the pickup meets the head. If it's loose, it will not suck fuel properly. Usually the anit-siphons work or they don't. Unusual to have them only work on a full tank. F_R has the right comments. Run it on another tank and see what happens.
  #14
Old October 18th, 2007, 08:45 AM
The remote tank is a 6 gaallon. I just replaced the sending unit and it has new seals and is in good working order. I will pull the pick up tube out again and look at it but I know that it is working fine I am really confused
  #15
Old October 18th, 2007, 01:51 PM
Tinman57 Tinman57 is offline
I've had lots of problems with brand-new primer bulbs. Quality control seems to be an issue. I've had to buy 2 or 3 to find one that actually works correctly.
  #16
Old October 18th, 2007, 03:28 PM
if it was the primer bulb it would do it all the time??
  #17
Old October 18th, 2007, 05:49 PM
Had it apart and nothing wrong? so I am really confused.. I am still leaning for the fuel pump.
  #18
Old October 18th, 2007, 09:14 PM
CharlieB CharlieB is offline
See if you can put a piece of clear hose in line immediately before the fuel pump.
While running and as it is failing can you see any 'bubbles' in the clear line?
Bubbles indicate air is leaking into the fuel line somewhere, a ppin hole before the primer bulb, poor hose to barbed fitting, something lets air get into the line just as if the tank has run out of fuel.
How do you know you have 1/2 tank, did you take off the sender and look/measure with a stick?
The gauge could be wrong!
  #19
Old October 18th, 2007, 09:57 PM
well I have a glass filter like I said in the beginning and there is no bubbles. so I dont know what to do.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fuel problems 9 1/2 hp evinrude pontoon chief Johnson & Evinrude Outboards 3 August 23rd, 2007 11:13 PM
Evinrude 15 - fuel problems petekeuer Johnson & Evinrude Outboards 5 May 12th, 2004 12:01 PM
Evinrude 50 / Fuel problems Big Brother Johnson & Evinrude Outboards 4 August 5th, 2002 04:30 AM
90 hp Evinrude -- Fuel Problems?? JIS1974 Johnson & Evinrude Outboards 3 June 3rd, 2002 05:22 PM
fuel problems evinrude rj Johnson & Evinrude Outboards 1 August 6th, 2001 01:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
