I have a 1982 Cobalt with an OMC 305 GM motor with a 4bbl carb. The poor thing sit idle for almost 3 years before I got it. I drained the old gas, changed out the points, plugs, plug wires, condensor and distributor. I changed the engine oil and the lower unit oil as well as added a bunch of seafoam.
Bottom line is the boat runs awesome now, except for one small problem. I can't seem to get the idle adjusted properly. It seems to stay around 1100 when the manual calls for it to be between 550 and 600. This is not a huge problem except when I go to put it in gear. Shifting is a bit klunky. I am concerned that I will damage the tranmission if I don't get it adjusted properly.
I have played around with the idle set screw but can't seem to get it down below that 1100 mark without causing it to spit and sputter.
As the manual suggests, I have tried to adjust the two pins (needles) on the carb. However, I don't think I am doing something right. Can anyone give me hand on the best/easiest way to adjust the idle down to where it needs to be?
Thanks,
Tony
Thanks,
Tony
