Ok...It's gonna be a four blader. I need to grip and grab the water off shore, get up on a plane and stay there at a lower speed and RPM, so I don't jump off the back of the waves and beat us all to death. Light 21' CC w/ 150 Johnson and T-top used for fishin'. Top end means nothing to me!
The Rev4 is the fancy one with the funky hub and all the press @ $500!
The Merc VenSura (AKA Offshore) is $430.
The Stilleto Bay Pro III is $390.
The Apollo S/S is $150 less than that @ $234.
Then there's the Renegade Offshore/Cyclone @ about 10 different prices (no longer recommended for >175HP and had to change the name for some reason!)
There's only ~$250 difference from top to bottom and I can afford any of them and I only have to buy it once! ALL the adverts read the same, however; "It's 4WD in the water, best prop in the world, high speed, doesn't use gas.....!"
I would sincerely appreciate constructive comments that might guide me in my selection. I can afford any of them, I just need to know which one does what, as they all read the same. I truly need your brains and experience!
Thanks so much for all you've taught me! Z
