Re: Questions for a 198? 125 force OB
I just did an 84 Capri/85Hp Force evaluation today. Compression was in the 150 psi ballpark, but that's with the shop tester that I know reads way high. You want the readings to be within 10-15% of eachother. Make sure you have good spark on all four, and check the gearlube. Look at the powerhead and check for discolored or bubbled paint, melted wires, or any other sign of a previous overheat. Make sure water is spraying out the back when it's running in the water. Top speed should be in the upper 30s/lower 40s, and full throttle RPMs should be 5200-5500RPMs. Make sure the transom and floor are solid on the boat. Make sure the steering isn't stiff, and make sure the boat systems work (lights, horn, etc.). We check used boats for customers frequently. It's usually an hour labor and maybe fresh gearlube and sparkplugs while we're at it. A wise investment.
