Hesitation on throttle up
wirewzrd
I have a 1995 Mercury 2.0 V6 outboard and when I throttle up from stand still the motor hesitates then accelerates to WOT. I cleaned the carbs with Sea Foam and then changed the plugs and still has same problem. Does anybody have any other suggestions?
CharlieB
Re: Hesitation on throttle up
Indicates slightly lean idle mixture
Sea Foam in the fuel isn't enough
Total tear down, soak, spray carb cleaner thru all ports and passages, follow with compressed air thru every port/passage
Should be fine again
