I have a 2001 evinrure 150 with a over voltage problem. Where is the voltage regulator ?
3 38oneton Recruit Joined Sep 5, 2007 Messages 1 Sep 5, 2007 #1 I have a 2001 evinrure 150 with a over voltage problem. Where is the voltage regulator ?
C Chris1956 Supreme Mariner Joined Mar 25, 2004 Messages 28,902 Sep 5, 2007 #2 Re: voltage problem If it is the same as my '98 Johnson 150, it will be behind the flywheel, on top of the two cylinder banks, under a plastic cover with 4 phillips screws.
