My Yanmar 4JH2-DTE overheated on sunday and coolant came out of the expansion tank.
The engine is 7 years old but i have only had the boat 2 years and it had 150 hrs on it when i got it and now has 310 hrs.
I have never changed the coolent since i got it.
I was planing to drain and flush the system with Radflush and then refill with new coolant. Also i`ll check to make sure the thermostat is working.
The raw water side seems to be pumping ok but i`ll check the impellor.
If this fails to cure the proplem then i was thinking of taking apart the heat exchanger to see if its blocked up with crud at all.
The coolant in there seems to be a brown colour.
Any ideas where else i should be looking or what it might be ?
I just hope it`s not the head gasket!!!!
Alan
Alan
