I recently purchased a 1957 Johnson 7.5 hp model number AD-11. The last owner indicated the motor ran in February. Did not have a 2 line tank to try to start at that time. After reading this site and others, I decided to do a thourough run through, including head gasket, impeller, carburetor, and new ignition parts.
In changing the impeller, I have the power head off.
Question is should I go ahead and put in new rings at this point? I do not know what the compression numbers were, but I do know that both cylinders had compression.when I started tearing it down.
If I should replace rings, what do I need (other than rings of course), and are there any secrets that will make the job a little easier.
Thanks.
Thanks.
