The boat is a 16' V fiberglass and iv tried to mount the thing twice now on the transom and works fine untill i take off then it turns off. Looking in the manule it says i can go through hull. So i seen people talking about in the bildge. The fish finder is a eagle the little cheap one. The thing is my bildge area is kinda wavy not flat so if i put it there what ever i use to glue it down will be thicker in areas is this going to work? And with the motor on the other side of the transom so close is that going to be a problem?
