  #1
Old October 13th, 2007, 09:08 PM
thefishingfreak thefishingfreak is offline
Default 1999 mercury 200xl blown piston, now what?
my friends boat.
a few weeks ago it felt{to me} like it was low on power and low max rpm arround 4800 max. momentarily, then problem seemed to disapear.
fast forward to the next weekend. my friend took it out over 1.5 hrs on plane to the fishing grounds. 6 hrs trolling. 1/2 way home they stopped to use the head. on power up #4 piston blew up.
this is where I come in as the somewhat mechanicly inclined friend.
I stripped it down, #4 looked like either 1" of the top ring broke? or 1" of the top of the piston broke? didn't look overheated/melted it just looked like a part{piston or ring} failure.
we honed the cyl. installed new piston/rings, deburred the head cover and buttoned it back up. runs super, only problem is it is down 800-1000 rpm max {4200-4400 max} and it sputters slightly on acceleration. with the air box off if you crack the throttles fast it just boggs down.
we ran out of time/daylight today to search for the cause but I suspect whatever it is, is what caused the piston failure.
any tips on what to look for first?
thanks.
  #2
Old October 13th, 2007, 11:21 PM
CharlieB CharlieB is offline
Default Re: 1999 mercury 200xl blown piston, now what?
How much 'coking' or carbon build up was under the rings and did you clean it ALL out?
What color were the piston domes?
How much carbon 'wash' was there down the sides of the pistons?
Did you thoroughly clean the carbs, rebuild the fuel pump and replace the impeller?
These are the tree items that most commonly cause an engine to toast. Not identifying the original cause dooms the engine to failure again, also remember to ADD OIL during the break-in, new rings and a new piston need break-in.
  #3
Old October 14th, 2007, 09:04 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
to me a dirty carb, could have been running lean, no providing enough fuel or lub.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old October 14th, 2007, 10:07 PM
'Coking' in the ring lands fills the void behind the rings, eventually squeezing/seizing the rings and they then fail to transfer piston heat to the cyl wall.
Substandard oils, excessive idle time, both contribute to early failure.
This is the reason for Deep Creep, top end cleaning
During rebuilds, reusing pistons, ring lands MUST BE SPOTLESS
Coke 'softens if run WOT for a period of time, shutdown without adequate cool down the softened coke solidifies, adhering to BOTH the ring and piston, seizing the ring, next start-up and immediate WOT, BOOM, piston seizure. Which is what happened when they made the short pit stop on the way back from fishing.
  #5
Old October 15th, 2007, 09:34 AM
thanks for the help so far.
here's some pics.
I pulled the center carb off and tore it down, but there were no obvious signs of any crud in it ? it was spotless.
I will start with the carbs- take them all apart and clean them out.
can you explain the deep creep top end cleaning?
Thanks again..
  #6
Old October 15th, 2007, 04:54 PM
Look at that ring land very carefully, where is the locating pin for that ring?
Screaming these things can loosen the locating pin, it comes out and makes a small mark on the wall while the ring begins to rotate until an end snags a port, then all DONE.
If that pin came out then I'd have to wonder about the other pistons.
There is a guy (Jay) on the Scream & Fly boards that specializes in top pinning pistons for those guys that have to twist them engines 'tight'.
Hopping it off another's wake and catching a bit of air revs it T. I. T. Tight too. These things catch R's too quick to be fooled with and have to be built a little different if he wants to turn it above the factory rating.
  #7
Old October 15th, 2007, 08:22 PM
ohh thats a good point..
the piston is down the boat. I will definitly check this tomorrow.
The locating pin belongs where the red arrow is. From my pics it sure looks like it's missing...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Buying a 2000 200XL Optimax vs. 1997 200XL timo14 Mercury & Mariner Outboards 3 August 11th, 2005 08:06 AM
Yamaha has blown piston tld1028 Yamaha & Suzuki Outboards 14 March 4th, 2005 04:13 PM
Yamaha has blown piston tld1028 Non-Repair Outboard Discussions 2 March 3rd, 2005 06:26 PM
battery isolator/ 1999 mecrcury 200xl dkline Mercury & Mariner Outboards 3 September 25th, 2003 11:34 AM
Blown Piston Joewharf Mercury & Mariner Outboards 7 May 28th, 2001 02:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
