  #1
Old October 13th, 2007, 03:58 PM
Cokert Cokert is offline
Arrow Mariner 115 2+2 fuel problems
I have a 93 model 115. On my first trip out the motor would only run if the bulb was constantly pumped (It sat for six months). It used a lot of gas. I have since rebuilt the fuel pump and cleaned and regasketed the carbs. I can get it running but to keep it running I have to constantly keep the choke on, and pump the bulb every few seconds. Anyone have an idea what to do next???? Please advise.
  #2
Old October 13th, 2007, 11:35 PM
CharlieB CharlieB is offline
Default Re: Mariner 115 2+2 fuel problems
Ensure those carbs are spotless, blow carb cleaner and compressed air thru all passages.
Floats set carb inverted dead level with carb base.
Throttle arm removed adj carb linkages, loosen all, flex/rotate and release each carb to seat throttle blade then carefully, gently tighten linkage soas when actuated ALL carbs respond. reattach throttle cam and adj rollor to pickup line.
Idle adj screws, start at 1 1/2 turn out, adj running for best idle speed + 1/4 turn fat
Adj idle speed w/ base timing adj screw
How oldl is the fuel in the tank?
How old are the plugs?
I run NGK BPR8HS at .032" gap far cheaper than the precious metals and I change every year.
  #3
Old October 13th, 2007, 11:51 PM
Well, when I cleaned the carbs I made sure all passages were clear. I used carb cleaner and replaced the gaskets. The top two carbs have adjustment screws on the sides, I think these are idle adjustments and I have moved them around a bit. Which ones are the timing adjustment screws???
The fuel, tank, primer bulb are new. The plugs are ??????? but I pulled them off a few days ago to do the compression check (OK) and they looked to be in good shape. I did not measure the gap.
The carb linkage does have the carbs responding in unison.
  #4
Old October 16th, 2007, 12:46 PM
I have tried adjusting the idle screws but it still does the same thing.
  #5
Old October 16th, 2007, 02:49 PM
MercFan MercFan is offline
Those carbs don't have idle screws. That's the idling mixture screw. Follow CharlieB there.
Then follow the rest of CharlieB's advice. Also try running the motor without the cowls on.
But at a guess I'd suspect a hole in one of the fuel pump diaphragms. Does the bulb ever get hard if you pump it while the engine is off?
  #6
Old October 16th, 2007, 10:48 PM
You've given us two very iimportant clues as to what is wrong.
1. you have to keep pumping on the primer bulb.
Generally, that is a definate sign that the fuel pump is NOT pumping fuel, you are pumping it manually. Either there is a fault within the fuel pump OR an air leak INTO the line AFTER the bulb and before the pump.
2. You have to keep choking it to stay running.
if this is at an idle, then the top two carbs with idle mixture screws on the side, near the top, are not passing enough fuel
. Turn the screws IN clockwise gently until they stop, DO NOT force them. Back the mixtures out 1 and 1/2 turns. This should be enough fuel to start and run, adjust running at an idle to 'best' idle speed then back out 1/4 turn more if running on a garden hose, only 1/8 turn if the boat is in the water.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
25 mariner problems austinmichael Mercury & Mariner Outboards 3 May 1st, 2007 12:47 PM
89 115 Mariner problems SPIDERSS Mercury & Mariner Outboards 4 June 15th, 2006 09:44 PM
150 mariner problems edeuka Mercury & Mariner Outboards 10 July 13th, 2005 01:42 PM
Mariner Oil Problems steveo555 Mercury & Mariner Outboards 7 June 1st, 2005 12:22 AM
Mariner fuel problem...fuel pump? LubeDude Mercury & Mariner Outboards 3 May 16th, 2005 04:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
