oil dripping from carberators
captain.mike
:eek: I have a 135 hp mer black mac. It was running fine, untill the oil alarm beep started beeping, so i headed it, then the over heat alarm went off, so i cut it off and loaded it up. I ck. the oil res., it was not low. the oil holding tank in the boat was 3/4 full, so i topped it off. could not find any problems, so i went back to the water., cranks great, trimmed off and ran for 1 mile, no beeping , then as i was turning around to come back, the motor went to an idiel. it also was missing some. later i notice oil dripping from the carberator. or even if thats part of the problem, but even today, it will only idiel. but cranks good and when you put in nutual, you can rive the engine up, but not in gear. any help?:cool:
