October 11th, 2007, 08:49 PM
71' evinrude 6hp.........a little white smoke
Ok.......replaced the entire water pump assembly, put it all back together, runs great but the exhaust blows white smoke. Not a ton of it but enough to make me wonder. Has been sitting upright on a sawhorse for approx 6 months w/o running. Do I just need to give it a nice long run on the lake to blow some cob webs out of it? I'm new at this, sorry if this is a stupid question.
October 11th, 2007, 10:57 PM
Re: 71' evinrude 6hp.........a little white smoke
But does it blow water? That's what's important. It's supposed to smoke.
October 12th, 2007, 12:27 AM
Look at your sparkplugs. Is one real clean?
If so, you are ingesting water in the cylinder via the head gasket or the exhaust port cover gasket.
October 12th, 2007, 08:21 AM
Quote:
Originally Posted by
F_R
yes it blows water
October 12th, 2007, 08:23 AM
will look at spark plugs. Wouldn't it run pretty rough if I was getting water in there? It runs great.
October 12th, 2007, 11:05 AM
BassBossAndy
Not necessarily.
October 12th, 2007, 01:03 PM
As suggested check the plugs.One or both may be extra clean.Oil smoke has
a blueish tinge and tends to linger "white smoke" is actually vaporized water,steam,and tends to disipate quickly.Motors can run quite nicely
if the problem isn't too bad.
October 13th, 2007, 12:10 AM
Well thanks for all the help, looks like all I needed was some freshly mixed fuel. Ran her accross the lake this evening w/o a hint of trouble. Thanks again.
Thread Tools
Search this Thread
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Similar Threads
Thread
Thread Starter
Forum
Replies
Last Post
Evinrude 48spl, heavy white smoke, milky substance, grey sludge, no power
hwesterman
Johnson & Evinrude Outboards
16
October 14th, 2006 09:36 PM
White smoke 4.3 OMC
lrlima
Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives
March 21st, 2006 04:34 PM
white smoke? bad.
letsbarbq
PWC (Jetskis, Waverunners, etc.)
August 2nd, 2005 08:41 PM
white smoke
toddbrown
Boat Topics and Questions (not engine topics)
6
July 6th, 2005 05:31 PM
White smoke
gwman
Yamaha & Suzuki Outboards
9
May 27th, 2003 12:37 AM
