evin 150 lower
Benny1963
for about 5months now i had been trying to get lower unstuck at crank
had posted lots of times got lots of responses and a lot of different ways.
had to pull motor off boat put on large a frame got a gap of 1/4 ''
between lower and mid sec and put steel bar in between and chained
it to floor . drive shft looks good didnt find corrosion that i expected
looked like old grease on shaft end splines look good .
is there any way shaft may have bent looks strait.
what would the result be if it is bent it is a stainless shaft
could i tear up crank splines or will shaft break.
or will i have vibration if i run .
was going to run it with fresh oil and see if it is smooth.
and if it is going to pick up water.
good idea or bad.
thanks to everyone that has helped me
b 1963
luckyinkentucky
Re: evin 150 lower
Have you checked the gear oil for shaving? Sounds to me like your gears are seized up.
