When I first purchased my boat it had an open area to the bilge compartment. The cover was missing so dont really know what it had originally. So I came up with this idea. A cover/ table. Its all scrap lumber from Home Depot, some decent paint and a large dowel. It latches tight with brass catches. It provides a great area when working tackle, making a meal or playing some cards.
Hope this helps someone.
__________________
86' Capri 1950 BR
Force 125hp
Desert Southwest
Very good idea.
I have an 18' capri that has the original snap cover which still works, etc. However I was thinking of doing a small equivalent table to what you have. I remember seeing just that on a couple of similar size Maxums covering up that space. Definitely more useful than a vertical cover and simply fold it down and out the way. Maybe include a couple of drink holders which I don't have for my two rear side seats.
__________________
Big Prairie
90' Capri- 90 Force
If it was easy, everyone would be doing it.
Now you need to drill some 4 inch holes in it and put some cup holders in the two front corners. Nice job, looks great.
I was thinking that the cup holders should be separate and permanently mounted just about the table on either upper surface/sides. That way if you are running with the table stored down and out of the way...you can still keep a couple of beverages supported if need be.
__________________
Big Prairie
90' Capri- 90 Force
thanks marc6... fortunately in my setup the rear stays have built in cup holders . I'd advise checking the clearance if you put holes and sunken cup holders. Reason is the bilge area is a great place for a tool box and other items plus the slope to the transom may strike when closing.
__________________
86' Capri 1950 BR
Force 125hp
Desert Southwest
