  #1
Old October 7th, 2007, 01:27 PM
stl stl is offline
Default 1973 evinrude 18 hp carb rebuild
I recently rebuilt the carbutrator. It runs but there is an annoying backfire/misfire. It seems to improve as the engine warms up. I used an original service manual for guidance. Yesterday while looking at the manual I noticed an exploded diagram of the carb. On the slow speed needle valve assembly there is a small piece called a needle valve bushing. The manual said nothing about the bushing only the retainer. As far as I nknow I did not see the old one either. Could leaving that bushing out be the cause of the misfire? There is a small piece in the kit that looks like the bushing. I can't believe I missed that. What do you guys think?
  #2
Old October 7th, 2007, 01:32 PM
bgbass.1 bgbass.1 is offline
Default Re: 1973 evinrude 18 hp carb rebuild
put the bushing in
  #3
Old October 7th, 2007, 02:33 PM
F_R F_R is offline
You can't see it, but it should be in there. Use a home made hook to get it out. Some people use a drywall screw, I've never personally tried that, but it sounds reasonable.
Is your miss at idle or high speed or all speeds? The bushing will cause a lean sneeze at idle, won't make much difference at speeds above fast idle.
  #4
Old October 7th, 2007, 02:52 PM
stl stl is offline
The miss is mostly at idle. It gets worse when you try to go from mid throttle to idle So the old one is probably srtill in there. Ill see if I can find it.Thanks
  #5
Old October 7th, 2007, 07:28 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Did it always miss or just after your rebuild? What plugs are you running? Torqued to spec?
__________________
Chris
  #6
Old October 7th, 2007, 09:30 PM
stl stl is offline
I should add this motor is new to me. It has not been run in years. So this is the first time I've had it running. I repulled the carb and recleaned the slow speed jet and reinstalled this time with the bushing that I forgot the first time. Same old story. Hard start with misfires, after about a five minute warm up the misfires goes away and I was able to get it to idle down nicely. I am running champion j4c's and I don't own a torque wrench but i plan on getting one. I dont know If you guys read my previous post but I had a problem wit the stop switch, which had cracked insulation I have a new one on order, and will replace soon. I personally don't think this has much to do with it because the trend is that the misfires seem to improve the more the motor runs. Thanks for all of your input so far any more thoughts are greatly appreciated, as I still consider myself ignorant on outboard repairs.
  #7
Old August 30th, 2008, 06:43 PM
MrGED05's Avatar
MrGED05 MrGED05 is offline
Here's a thought for you.
Since the engine is hard starting, misfires at mid throttle and then behaves nicely after warmed up, I think you should check for a vacuum leak or a poor fuel connection or gasket. As the engine warms up, it actually expands a little bit. Perhaps enough to swell and seal off a vacuum leak or a bad carb or intake gasket.
Gary
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 evinrude 18 hp carb rebuild stl Johnson & Evinrude Outboards 4 September 30th, 2007 10:32 PM
1973 50hp evinrude carb adjustments. 94saleen Johnson & Evinrude Outboards 1 July 7th, 2007 04:40 PM
'84 Evinrude Carb Rebuild blhpzlb Johnson & Evinrude Outboards 2 May 10th, 2005 07:07 PM
Carb rebuild ?'s on Evinrude vro 140. nivram Johnson & Evinrude Outboards 9 April 20th, 2003 02:41 PM
Evinrude 25HP 1973 Carb jet sizes G DANE Johnson & Evinrude Outboards 0 April 14th, 2003 10:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
