  #1
Old October 7th, 2007, 09:55 AM
JBall JBall is offline
Default '96 Evinrude carb adjustments
According to the SELOC manual for this '96 150, there are no adjustments on a "B" type carb. However, it also says there are two fixed orfices that I cannot find. There is one slotted screw with a spring behind it, much like an adjusting screw. I turned one all the way in counting turns (6) and reset it. The motor runs at 1000 rpm idle and coughs and sputters a little in no wake zones. Any idea of how to smooth out the idle? The carbs are probably clean since this is a relatively fresh rebuilt powerhead. Thanks, J Ball
  #2
Old October 7th, 2007, 11:12 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: '96 Evinrude carb adjustments
the high speed fixed jets are in the bottom of the bowl behind the drain plug, the low speed are at the top of the carb. requires special tool. they are not adjustable. must be spotless.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old October 7th, 2007, 03:30 PM
Do you have a starting point adjustment for the slotted screw with the spring. I read somewhere it may be idle mixture, but I don't know. As I said earlier, all six are at 6 turns out. I did try adjusting them a little, very little difference could be heard. JBall
  #4
Old October 14th, 2007, 01:00 PM
In case anyone is curious, I never did get an "official" answer as to the starting point, but this morning I played with the adjustment a little. I think six turns out is a good starting point, I turned mine in 2 turns from there, and it wouldn't idle. Opened them all to 5 turns out and then just tweaked them 1/8th turn at a time. Now it idles at about 1050rpm on the hose, I suspect it'll lower a little in the water. JBall
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 50hp evinrude carb adjustments. 94saleen Johnson & Evinrude Outboards 1 July 7th, 2007 04:40 PM
1979 Evinrude 140 carb orifice plug adjustments? Theoutdoorsman Johnson & Evinrude Outboards 7 September 5th, 2006 01:26 PM
Carb Needle Adjustments For Asorted Carb Variations by Joe Reeves OBJ Engine Frequently Asked Questions (FAQ) 1 July 7th, 2006 01:40 AM
1989 -25 Horse Evinrude Carb Adjustments dakemaman Johnson & Evinrude Outboards 1 July 4th, 2005 11:35 AM
'56 evinrude 15hp carb adjustments mudhen Johnson & Evinrude Outboards 2 May 7th, 2003 04:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
