Mercury I/O B3 starting problems
OK, took the boat out today, no problems starting from the dock, the gas pump(filled it up in preparation for winter), or the pump out. Took a quick run for one last dip in the lake and when I got back on, engine wouldn't start - sounded like it was cranking fine. If I used throttle only, it would start with about 50% throttle, but would not idle. If I was quick, I could start with throttle only and then go to neutral and back in gear and it would run fine. Was getting two beeps from the smartcraft. It's a 2002 B3, 5 (or 5.3)L. Any ideas what could be causing this? Impellers where changed a year ago. Is vapor lock a possibility?
TIA.
