  #1
Old October 3rd, 2007, 04:14 PM
whitepursuit2150 whitepursuit2150 is offline
Default 1994 Yamaha 200 saltwater series rough idle
I have a 1994 pursuit 2150 with a 1994 200hp yamaha saltwater series motor. The motor has been running great since i rebuilt the carbs and changed the plugs 4 months ago. I use the boat 1-2x weekly. recently (this week) the motor started running rough at idle, with the powerhead shaking a lot. I have also noticed a film of oil/gas on the water when I am sitting still with the motor running. I dont really have any problems starting the motor. After I motor up to around 2500rpm-->wide open, the symptoms disappear. I am currently undecided between a cracked plug, bad plug wire, timing being off, or low rpm coil pak going bad. Any feedback?
Thanks!
  #2
Old October 3rd, 2007, 05:17 PM
njohnson1960 njohnson1960 is offline
Default Re: 1994 Yamaha 200 saltwater series rough idle
You have ethanol in your gas? I will not fill up any more without adding STARTRON. My 115 Yamaha was running really rough at idle I had to rebuild Fuel Pump and Carbs last year because of the algae growth issue. I added STARTRON and the engine has never run better since it was new in 2003.
  #3
Old October 3rd, 2007, 09:23 PM
No, no ethanol. I am in Florida, and the stations that use E85 have it pretty well marked.
  #4
Old October 3rd, 2007, 11:42 PM
Ray Neudecker Ray Neudecker is offline
Did you replace the fuel pumps?
  #5
Old October 9th, 2007, 02:55 PM
No, I didn't think about replacing the fuel pump. Do you think that may be the problem, even though the high RPM's aren't affected?
  #6
Old October 9th, 2007, 07:31 PM
The symptoms of rough idle and oil and fuel in the water indicate a stuck needle or leaking fuel pump. Basically, I have found that if fire is there at any check point that an electrical problem is very unlikely on those models.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1998 Yamaha 130 hp saltwater series. Jpmt Yamaha & Suzuki Outboards 1 May 9th, 2007 10:58 PM
96 Yamaha 200 Saltwater Series robertjohnston Yamaha & Suzuki Outboards 9 August 21st, 2005 05:34 PM
1996 Yamaha 200 (Saltwater Series) robertjohnston Yamaha & Suzuki Outboards 4 August 2nd, 2005 10:45 AM
1998 Yamaha 200 Saltwater Series will not idle and rpm's fluctuate tkgjax Yamaha & Suzuki Outboards 2 May 10th, 2005 08:33 AM
200hp Yamaha Saltwater Series boatpoor Yamaha & Suzuki Outboards 4 May 10th, 2005 08:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
