  #1
Old October 3rd, 2007, 02:57 AM
freddyray21 freddyray21 is offline
Default 1972 Mercury 4hp fuel issue
Just picked this one up the other day. Of course no spark. They never do it seems. Pulled the flywheel and found the points glazed over as usual. Also the wires from the stator to the coil and the points to the coils were badly frayed. replaced the wires, cleaned and regapped the points and voila spark. Carb looked real clean and got it to fire on the second pull. Once running had to hold the choke half on until it warmed up a bit then it would idle fine without the choke on. Let is sit for a bit while I worked on something else. Went back to start it and would not start. I had not reprimed it so I took the primer bulb and found it soft. Pumped it back up and got it to fire and run good again. It seems like it loses it's prime went it sits for a few minutes. Tried it a couple of times and the same thing. Would have to prime it again to get it to run. A couple of things. This does not have a kill switch so I am idling it down low and choking it to kill it. Secondly, this originally had a metal gas line and some one replaced it with OMC rubber fuel line so there maybe an air leak? lastly the connector to the motor does not seem to snap in good and seal. Another air leak? Once started it runs fine and will stay running.
  #2
Old October 4th, 2007, 01:59 AM
Default Re: 1972 Mercury 4hp fuel issue
bump
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1972 CV-16 with a 1972 140HP Mercury OB...Help please canadianb Non-Repair Outboard Discussions 3 July 31st, 2007 09:20 AM
Engine or cable issue?? 1972-74 Super 65 Evinrude OB lwcrew Johnson & Evinrude Outboards 4 December 14th, 2006 08:45 PM
1972 Johnson 50ESL72c charging issue RCAUTO Johnson & Evinrude Outboards 3 September 22nd, 2005 07:26 PM
Engine dies after long runs (fuel issue), fuel hose? ShawnQ Johnson & Evinrude Outboards 8 March 19th, 2004 02:12 PM
Fuel/Oil Mixture 1972 Mercury Outboard BoatGirl Mercury & Mariner Outboards 3 June 21st, 2003 05:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
