I've got an 1985 2 hp Evinrude motor for my porta-bote. I rebuilt the carb. and noticed leaking fuel last time I tried to start it. This makes me think the float is not adjusted correctly or the needle isn't seating properly. The manual said to use a particular tool to set the float height with the top inverted. i haven't the tool and the new float was parallel with the casting so I put things together. I've seen spec books say to set it up this way for other carbs. so I gave it a try. It doesn't seem to work. Can anyone advise me on setting the float on this simple carb? Thanks
