jaydee4854
- Aug 27, 2007
- 3
While on the lake i was full throttle when the motor went to less than 1/4 power on it own and started to backfire. Changed gas tank same thing. Got it home put the muffs on and started motor. Same problem at idle. Checked fuel filter that looked good. Changed both sparkplugs,same problem. Took both plugs out,both plugs looked the same,they looked burnt meaning black and were dry. I think this is normal. I did a spark check on both coils and i got a good spark arc on both. Checked the compression on both cylinders,one was 130 the other 125. that seems good. The one thing i forgot to do is squeeze the gas bulb while its running,i'll do this in the morning. I'm running 50:1. All in all its still backfiring with white smoke and stalling and running at less than 1/4 power while the throttle is wide open. Im thinking theres some dirt in the carb jets. I've never rebuilt a carb before,any advice on this would be helpful. also any other advice on something else it could be would help. Maybe timing not sure how to do that either.
Thanks
Thanks
